When running Microstation, an error occurs stating 'Compile error in hidden module: export' (see pic 1)
Applications version installed is as follow-
1. Microstation Connect Edition Update 13 v10.13.01.01
2. Microsoft Visual Basic for Applications 7.1 (x64)
3 Microsoft Visual Basic for Applications 7.1 (x64) English
What are you doing when this error occurs? Is it right when you try to open Microstation? Is it when you change between files? Is there a specific tool that throws the error? Are you trying to run a custom VBA?
We will need more information to try to track this error down.
MaryB
Although the following Wiki article is for AECOsim BD it may be relevant when it comes to this error.
https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/43025/vba-error---compile-error-in-hidden-module
As MaryB has suggested, this may be related to a custom VBA. Was this written for the current MSCE U13 version or was it from an older version?
Thanks for the link but not doing anything related to VBA, getting this error while exporting files to excel. Don't know about MSCE version. When I select on 'Help' it says to unprotect a project in the code which I cant seem to be able to do neither do have the proficiency.
Devang Singh said:getting this error while exporting files to excel
What is it that you export? What key-in or tool in MicroStation are you using when you export a file to Excel?
Devang Singh said:Don't know about MSCE version
But in your initial post you stated that you use MicroStation CONNECT Edition Update 13 v10.13.01.01. Is that not the case?
Yes thats the software installed. What I meant was that I don't know if its written for that particular software(?) Trying to export dgn files using the export option in the software.
