Hallo, suddenly from a couple of days (I haven't done update or similar) micorstationhang for verage 5-7 second every 3-4 shortcut comman.
I work only with Position mapping and this is quite annoyin when the program freeze. It hppened the the program freeezed also when I save the file or switching to the preferences tab..
I have a crash (without error window) just after one hour af work and endless freezing.
CONNECT EditionUpdate 14 - 10.14.0.109
on win10 pro version 1903
Nvidia quadro M2000
64 GB RAM
Are you working locally, or remotely? Are you working over a VPN?
MaryB
Microstation 08.11.09.829Power GeoPak 08.11.09.878Power InRoads 08.11.07.615
It may be helpful for you to produce Hang Dumps or supply Crash Dumps for us to investigate what is happening on your system.
https://communities.bentley.com/products/microstation/w/microstation__wiki/39836/generate-a-hang-dump-with-procdump
https://communities.bentley.com/products/microstation/w/microstation__wiki/39038/generate-type-7-minidump-with-page-heap
You might also like to raise this as a new Service Request for our support team to investigate.
thanks for answering, I'll try to generate a dump file.
I'm working locally, I'll generate a dump file and post it.
hope this dumpfile could be helpful, I had to use a Wetranfer 'cause the file are bigger than 60MB
https://we.tl/t-R5KpMQnAJm
