how to raise or low an element elevation, for example, I want to raise the culvert elevation 1m, normal I can move in the front view, or change the two end elevation, do we have a tool select the element and direct add 1m to the element, so the element raised 1m? thanks.
To me it seems like move element is the way to go.
The keyin dx=#,#,2 will move the element 2 units in Z keeping the X and Y intact.
/Krister
Owner consultant at Surell Consulting AB
Similar with accudraw: Select e.g. move, select the element and just press PP (accudraw in CE) Then you get the dialog for "Datapoint Input". There direcly key #,#,2. good e.g. for relative (like dx=) or absolute (xy=) values (a bit more modern version of the good old keyin window)
