We're migrating to CONNECT EDITION, I understand V8 doesn't have the Font Utility to allow users to purge and copy fonts. Please suggest how to clean up and purge among font resource files. Thanks
Kim
V8i does have a font utility - I just used it not very long ago. CONNECT may not. if that's the case, keep a copy of V8i as long as you can. SS10 uses the CONNECT licensing system but is still a V8i program.
MaryB
try the following keyin:
mdl load fontutilities; Font Utilities Dialog
Timothy Hickman
Main: 877 627 3772|
Just checked and in CONNECT U14 the Font Utilities tool is included.
For more info on the font utilities see:
https://communities.bentley.com/products/microstation/w/microstation__wiki/8748/edit-font-rsc---font-utilities
I will have our IT upgrading us to Update 14 of CONNECT. It's working in MS 08.11.09.829 but not in our current CONNECT U12. Thank you so much for the useful info.
Kim Le said: It's working in MS 08.11.09.829 but not in our current CONNECT U12
It works for me with MicroStation CONNECT Update 14.2
