I am in Microstation Connect Edition Update 14 - Version 10.14.00.109
I have created a custom tool. It sets the level through a level template. Engages the Cloud by Points Tool. Turns on the arc radius toggle and sets the arc radius length to 0.1. My question is, can I make that distance of 0.1 scale according to the annotation lock?
Thanks!
The only way I can see to do this is through a VBA like the one that's shown.
Private Const BASE_RADIUS As Double = 0.1 Sub SetPointCloudRadius() Dim ScaledRadius As Double ScaledRadius = BASE_RADIUS * GetActiveAnnotationScale CadInputQueue.SendCommand "place revcloud points" CadInputQueue.SendKeyin "set item toolsettings cloudarcradiustoggle=1" CadInputQueue.SendKeyin "set item toolsettings cloudarcradius=" & CStr(ScaledRadius) End Sub Function GetActiveAnnotationScale() As Double Dim sd As SheetDefinition Set sd = ActiveModelReference.GetSheetDefinition GetActiveAnnotationScale = sd.AnnotationScaleFactor End Function
In this case you would change the Key-in property of your custom tool to something like VBA RUN [mvba projectname]SetPointCloudRadius
Then remove the arc radius Dialog Item Setting
Rod WingSenior Systems Analyst
Answer Verified By: Heidi Taynton
This was perfect! Thank you so much. I"ve played with VBA before, but I haven't touched it since moving over to Connect. I did keep one of the dialog item settings so that the arc cloud toggle was on.
