Can I create MText that is Formatted with bullets and/or numbering?
I was wondering if there was a way to create multi-line text like AutoCAD let's you do? So in AutoCAD, you can create text via the MTEXT and you can format the text with rows, columns, auto-adjust, manual, bullets, numbering and unlimited possibilities. But the guy I asked around in the office I just started in says he doesn't know how to do that and he just does his text via the regular text dialog where every time you hit return its its own single line, which is annoying if I am creating notes in a drawing and I have 85 notes and then the engineer removes a few, then I have to renumber and move everything every time. In AutoCAD I can just delete the notes and the numbering will adjust accordingly and I can move the columns and rows to fit my real estate. Thanks in advance.
  • It is always a good idea when posting your queries to advise the software and version you are currently using.
    MicroStation Forum best practices
    In MicroStation CONNECT Edition we have included a new Text Editor that allows you to format using the various methods you have listed.
    The Text Editor Icon Bar and Tab Ruler include many of the capabilities you would see within the AutoCad text editor.
    https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v16/en/WordProcessorTextEditor.html
    Andrew Bell
    Technical Support
    Bentley Systems
  • you can format the text with rows, columns
    Perhaps a MicroStation Table would provide what you want?
    Regards, Jon Summers
    LA Solutions
  • That doesn't appear to have settings for an automatically bulleted/numbered list. Are there additional options not shown in that dialog by default?
    This would be helpful, especially when dealing with entities that require a lot of notes and lists in their plans.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
  • create multi-line text like AutoCAD let's you do? So in AutoCAD, you can create text via the MTEXT and you can format the text with rows, columns, auto-adjust, manual, bullets, numbering and unlimited possibilities
    I feel your pain, I found in v8i the text editor  quite clumsy and poorly documented in the help, especially the para and indenting I can make it work in MStn as is, after a fashion but never got the bullet point to auto number nor  to reset itself or renumber automatically, but my work around that always works is to open MS Word and do all the fancy text note bullet points and formatting  there but be careful your font needs to be as close to what you work in ms  as some things like bullet dots don't exist in all fonts.....  but with true type it works most often .....then copy paste it into the word processor , (you may need to mix fonts in the word processor to get the bullets right) ... and it works beautifully.. then I know for next time if I need to reformat ie remove a number midway I open text editor and  copy paste it back into word and do it there...
    Not what you want to hear, I know,  but its a workaround that's quick and dirty but very easy and FAST.. and I never worked in 20 years in drafting  where they  don't  have MS office on every pc.. I read the html in the link provided for CE but IMHO it looks like it still hasn't improved or become easier the two little tabs are still there for line indent and para indent.. no mention of bullet points or auto numbering.. .so IMHO still sadly lagging even further  behind our cousins using ACAD Mtext  functionality.
    Lorys
    click link to PM me
  • Yes! Exactly. I recently switched companies and have been using AutoCAD for decades and now this company uses both as some jobs are required to be done and submitted in MicroStation. So it's a learning curve for me. I'm excited to learn the software, but get frustrated when I realize all the options I took for grant it with ACAD. Also, this company is using MicroStation V8i Select Series 4. Shouldn't they use a newer version. I feel like they should and i should ask them.
    C. LeMay
    MicroStation V8i (SELECTseries 4) version 08.11.09.829
