I have deleted my named boundaries but those boundaries are still tied to other sheets (so I still get the small magnifying glass around the boundaries that have been deleted)
I have no interest in maintaining the connection between this file (the one with the name boundaries) and whatever sheets they are "informing"
How can I remove that association and delete the magnifying glass?
What happens if you right-click on the magnifying glass - do you have an option to Delete or Remove?
MaryB
Hey, did you ever figure this out? I'm having the same problem right now and can't get rid of the magnifying glasses. Thanks!
I just click and right-click on things. Seriously. There's a lot hidden in right-click menus and options.
Nothing comes up when you right click the magnifying glass, and when you click it the only options are "open design model" or "place view on drawing or sheet"
When you removed the Named Boundaries did you also remove the associated Saved Views?
If you still have the Saved Views you should remove those as well.
You could also just turn off the display of the magnifying glass by turning off the Markers View Attribute.
Rod WingSenior Systems Analyst
