I'm looking at migrating from V8i to Connect Edition, something I think I will need to do sooner or later. It looks kind of promising compared to how it looked three years ago. The only problems I’ve encountered so far are the following:
Trim to intersection doesn’t behave as I want when trimming line strings. See attached file. The lines won’t connect in CE, and the part supposed to be “cut away” is going bananas. Is this a bug?
Paste text from clipboard doesn’t use the latest text attributes or layer style. In V8i this worked fine. Why?
Thank you!
Sincerely,Kris
Hi Kris,
You're right about the Trim to Intersection command. It isn't working correctly.
CE is not trimming/extending the correct segments of the linestrings. This is a non-sensical way for this command to operate and is not consistent with the way it worked in V8i versions.
Regards,Ron
Do you know if it is like this in all versions of CE or just CE 14?
I just updated to CE ver. 10.14.02.01 and the issue is still there.
I am going to create a new service request for this issue.
FYI:I just received the following email response:
Description: TRIM TO INTERSECTION illogical operation Product: MicroStation Product Area: Manipulation I would like to inform you that this issue resulted in Defect Report 1100007, and will be evaluated by the product management team for our regular SELECT updates.
Great to hear Ron. Keep us updated!
Hi Again Ron,Have you heard anything about this issue? My whole group is waiting for this to be fixed so we can move over from V8i.
Hi Kristoffer,
I haven't heard any news on this issue. I just Requested an Update through the Service Request Manager, so hopefully I'll get a response.
The latest MicroStation Readme doesn't list it as resolved either.
