Hi to all,
I have the following question. I have an existing DGN file with 3 types of models in it, design models, drawing models and sheet models.
If I go to the model dialog and I do "copy model" from existing design model, then this model is copied and all the references are perfectly shown into the references dialog.
If I do the same with an existing sheetmodel, then also the references are present in the references dialog.
But if I do "copy model" from an existing drawing model, then the references dialog shows no references! After I close the DGN file and reopen it, then alle the references are shown again in the references dialog.
Is this a known issue? Is this a bug or does it work differently with drawing models?
Can somebody explain the differences to me? I would be very thankful.
I am able to reproduce this using MicroStation CONNECT Edition Update 14, I will have this reviewed and if required file Defect.
Following further review this issue was found to be addressed in the next upcoming release (Update 15). Thank you for reporting.
We are working with Update 17 and have the same issue? Since it would be addressed in Update 15, is there a fix available?
I have been able to reproduce this in Update 17.2 and Bug 1085218 has been filed. Thanks for reporting.
As mentioned in the original post reopen the file / copied model restores the references.
