We are having issues with CE whereby vector lines are not showing through a raster. If the file is opened in v8i then they do. Note that the rasters are set to the background.
Why is this different and how do I make the vector lines show through the raster when using CE?
This is the view in Connect.
This the view in v8i, with the lines showing through.
stuartw said:Note that the rasters are set to the background.
Set to the background where...
What configuration variables that concern reference and raster attachments have you defined...
Can you share the file for testing?
Is the model 2D or 3D and are the lines possibly being referenced in?
Jon Summers said:Set to the background where... In the V8i Raster Manager dialog? In the CONNECT Raster Manager dialog?
Raster dialog for both.
Jon Summers said:What configuration variables that concern reference and raster attachments have you defined... In MicroStation V8i? In MicroStation CONNECT?
None for both.
David Trejo-Rodriguez said:Can you share the file for testing?
Not sure. It's not my file. I'm just the messenger!
