I'm new to microstation, bare with me. I'm working in connect edition. I have a sheet model that I'm dimension a model I referenced in. I'm trying to place dimensions where the extension lines are center lines. I opened the dimension style, under symbology, I changed the extension lines style to (7) center. When I dimension in the sheet model on the referenced model, the extension lines show as continuous, not center lines. If I pick anywhere other than the referenced model (empty space) the center lines show up.
If I repeat the above in select series 10, it all works, am I missing something in Connect to make the extension lines show up at center lines in connect when dimensioning a reference model?
Hi Lonnie,
We noticed this too and we've already filed a Defect 900748 for this issue.
Thanks and keep reporting,
Manoj
what version of MicroStation CE was the defect filed under? I have CEU14 10.14.02.01 and it is working correctly for all model types.
10.12.00.40
Are you able to update to the most current version?
MaryB
I am not
You may need to get your CAD manager or IT guys involved. Every iteration of MicroStation has fixed any number of bugs (and unfortunately often introduced a few more) as well as adding functionality, speed and stability.
