I can not delete a dimension style. Remapped elements and can not delete dimensions style
If the dimension style is coming from a DGNLIB file you won't be able to delete it
MaryB
try compress too, but like mary said will not remove if dgnlib is attached / loaded
Lorys
What happens when I send the drawing out to the customer?
If you do not send the client the DGNLIB and the style is not used in your drawing, that dimension style will not show up.
I am not an administrator so will not be sending out dgnlib files. I made a text style set to center center so I could add it to my dimension style and the text would be centered (per advice on this forum). As it is, I have to center by adding spaces to the text, exploding or just any way I can. The plan was to use it like an AutoCAD block attached to the drawing. Dream on.
Since I can't use a dgnlib file of my own, I cannot create cell libraries, text styles, dim styles, layer libraries. I guess my time spent looking into this feature has been useless. Are there any other features (traps) I should be on the lookout for? I guess it's not possible to make a custom anything unless I do it for each drawing, if that is even possible?
