Hi there,
I print a lot of pdf files, on microstation V8. Each time I want to print one, and after hitting Cyrl+P, I have to grab the mouse to touch the little printer, on the upper left corner.
Is there a way to touch the printer button with the keyboard? I tried TAB several times, but never worked.
I have a Portuguese-pt keyboard, if that's useful as information.
Thanks, greetings everyone.
Alt+f then p
Try Ctrl+P and Enter. This assumes that everything has been configured to your requirements and that the correct driver and settings have been defined.
Can I suggest you make a command string and add it to an F key and you can even add the execute so it prints straight away the string will have print command, size of paper, the printer to use maximise etc and if there is nothing outside the sheet boundary will fit to the sheet edges.... I published how to do this step by step a long time ago under one stop printing or one shot printing in this forum but it may have go to archive when you use the search choose everywhere...
I would also advise changing the workspace config variable
If MS_PLT_AUTO_FIT_VIEW is set to '1' or '2'
Lorys
Hi.
Ctrl+P works. But, after that, just toutching "enter" doesn't do anything. I have to go to the printer button with the mouse.
Could you tell me what should I configure, then?
I searched under "print settings", but found nothing...
Thanks in advance.
My previous answer
Should work just fine. Everything can be done without a mouse.
