Hi to all,
Maybe someone has this problem too and can explain why this happens and how to fix it?
Some colleagues of mine, when opening a dgn in Microstation CONNECT, suffer from spontaneous changes in the background color of dialogs. For example the dialog for switching levels on/off. I myself had this problem for a while, but not for quite some time now.
On the internet I could find that the background color of the dialogs has something to do with the settings of Windows (under Personalize), but why the background color suddenly changes when opening some dgn's I cannot find out. And so a solution to the problem is also unknown to me. Sometimes the dialog of the levels on/off suddenly has a blue background and sometimes pink letters, making it almost unreadable. We can't fix this! In this example below the levels on/off dialog has suddenly a blue background with black letters.
Is there a setting somewhere in Microstation that influences this?Or does anyone know where Microstation might keep this info?
Can we fix this with some of the Windows settings maybe?
Jip
Apart from the standard colors defining whether levels are on, off or active you may have one or more defined color tables for your menus depending on which workspace may be used. For MicroStation CONNECT Edition the default color table file for your menus is located in the following folder.
C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\Default\Data\menucolr.tbl
