How can I clip the reference inside the element? Every time I'm trying to clip it, it's clipping outside.
Using Microstation V8i SS4. Thank you!
That kind of "clip" is called a "mask" in MicroStation, and it is a different tool in the reference toolbox.
Clip is to set the outer boundary of a reference and Mask is to hid parts of the interior.Clip will work with an element shape, while Mask only works with a fence (but you can create a fence from an element so it's not that much work once you have your shape).
MaryB
Answer Verified By: Lucilia
