Dimension Text Alignment
I have a question that hopefully you can help me with (or maybe it's just not possible with MicroStation currently). I am looking for my dimension text to remain aligned with the dimension line when docked, but would like to be able to rotate it horizontal when it is pulled off of the line. is there a way to do this? it seems I can have only one or the other.
On top of this, I also noticed that even with placement set to manual or semi-auto, dimension leaders for angular dimensions don't let you place the text where you want, it just picks it for you.
regardless, see the below images for the alignment issues:
aligned:
you can select modify element and then move the leader but it then looks like the following image
Horizontal:
ideally, it would be nice to have a horizontal text alignment when undocked, and be aligned with the dimension line when docked.
