Line style is not applied on a part of a line
im wondering if anyone knows why a line style is applied on one part of a complex chain but not the other and how I can go about to make sure that the line style is applied across the whole line and not only a part of it.
Thankful for all the help I can get.
/Dmitriy
Parents Reply
  • Hi Dmitriy,
    This screen shot of the Line Style Editor shows the DASHDOT line style definition being used in your example.
    Because the Stroke Pattern Attributes has Single Segment checked, the line style is restarted for each segment. Since the length of each linestring segment (about 3.5m) is shorter than the dash defined in the line style (4m) you won't see the rest of the line style.
    If you uncheck Single Segment the line style will continue uninterrupted from one segment of the element to the next.
    Ron
