Can I select particular text or string from the file name to be displayed if we create the field for File name in Microstation V8i SS3.
Suppose My File name is "Check14.dgn" & I create the File name Field inside the File and I only want to display "14" what can I do?
TIA
Hi Nischint,
Nischint Agarwal said:Can I select particular text or string from the file name to be displayed if we create the field for File name in Microstation V8i SS3.
Don't know if it's possible, but directly from field dialog Root you'll only get True/False:
José
As Jose, mentions this is currently not possible, however we would like to understand more about your requirement and I will follow up with you via Service Request.
In addition if not aware Idea's can be posted here
Carl Myhill
Technical Support Engineer
Bentley Systems
This has resulted in Enhancement Request 1112216 being raised for Product Management / Development consideration.
