So a colleague, who had a plug-in in her MicroStation for Autodesk Vehicle Tracking, drew a bunch of car parking spaces in MicroStation. I do not have the plug-in and she can not longer access the design file.
There are lines, probably created by the plug-in, on a level called BayConstruction, that can not be seen or selected while I am in the design file. They are visible however, in live drawings. The weird thing is, they cannot even be turned off in some of the live drawings.
How can I delete them?
Hi Yuan Ge,
Yuan Ge said:I'm wondering if I can see those invisible lines
Have you check if this invisible lines are in Construction Class?
Go to View Attributes [ CTRL + B ] to see if Construction Class elements is turned on or off.
José
Answer Verified By: Yuan Ge
I have now glimpsed a higher dimension.
hi mate long time hearing from you
At my work we use these apps all the time I've not heard of anyone not being able to see the tracking ... Have you checked to see what version the DWG file is in ?
Open the dwg with acad and save it back down as 2013.. it should now be visible in V8iss4 or even ss3... if you upgrade to V8iss10 you get a few more versions higher..
Matt says to say hello too.. any more probs send me some demo test files in a pm to look at ok?
Lorys
