Hi
I'm going crazy over problems with my patterns.
Here's the pattern in the cel-library: (size approx 1mm across)
Here is that pattern placed in a drawing file. On the left placed with the annotation scale of the drawing set to 1:1 and on the right set to 1:10.
The size placed in 1:10 is approx 0.1mm across and the 1:1 is 0.01. It means the pattern is 100x to small.
Here the annotation settings when placing the pattern on the right side in the image above.
And here's the settings of the pattern model:
What I'm doing wrong here?
Running OBD update 6 (Microstation update 13).
Robert
It might be the file Unit Of Resolutions (UOR) between the two files. so as a test try using the TRUE SCALE option
Ian
True scale or not, I still get the same result.
do you get the same results if you place it as a cell - rather than use it as a pattern ?
Timothy Hickman
Main: 877 627 3772|
Could you please post the DGN (a small portion is fine) and the cell library?
MaryB
5488.pattern.dgnBTBPattern.cel
