Batch Process to Rotate Border and View
I need to figure out a batch process for many files to rotate a border 180 degrees (which is a cell), rotate the view 180 degrees, fit view then save settings but I cannot figure out the commands. Any help would be appreciated.
  • Chuck,
    These keyins will select the cell…
    MDL SILENTLOAD SELECTBY DIALOG
    SELECT TYPE NONE
    SELECTBY TYPE CELL
    SELECTBY CELLNAME <cellname>
    SELECTBY EXECUTE
    Determining the point to rotate about may be difficult If all the border cells have been placed with different origins. This example shows rotating about the element center/origin. Depending on the origin, this may or may not get you what you’re looking for. (XY=0,0 is simply issuing a data point to accept the rotation)
    AA=180
    ROTATE
    SET ITEM TOOLSETTINGS ROTATEABOUTORIGINTOGGLE=1
    XY=0,0
    If you don’t want to rotate about the center or origin, and know the point you to rotate about you could do something like this, where XY= the point to rotate about.
    AA=180
    ROTATE
    XY=17,11
    These will rotate the view, fit, and save settings.
    ROTATE VIEW RELATIVE 180
    SELVIEW 1
    FIT ALL
    SELVIEW 1
    FILEDESIGN
    Hope that points you in the right direction.
    Matt
    Answer Verified By: Chuck K.
  • Thanks Matt! That got me 99% there. The border does rotate but not in place which isn't that big of deal. You should present a webinar with GLBUG Slight smile
Reply Children
