is Microstation V8i going to expire ?
V8i will not be supported in future but it doesn't mean that license will not be available.
Ok. What kind of support you mean?
Support from Bentley Systems.
See this table for details - https://www.bentley.com/en/desktop-applications
also
Announcement: SELECTserver support discontinuation and desktop application deprecation effective January 1, 2021.
LEARN MORE>>
The Select License Server will be taken offline at the first of the year. This will affect any version of software that uses this licensing scheme - anything prior to SS10. SS4 and earlier will have no license available unless Select licenses are converted to node-locked licenses. You would need to get in touch with your Bentley Administrator to get that process rolling.
SS10 runs on the Enterprise licensing, and will be available and supported after the first of the year.
MaryB
What about pre-XM versions with SS gateway?
