I would like to set my Drawing Boundary in the reference dialog box to always default to NONE and by Visible Edges default to DYNAMIC.
Right now they set to NEW and CACHE by default. I would like to change those defaults to NONE and DYNAMIC.
Thanks.
Hi Brian,
Brian MacCartney said:I would like to set my Drawing Boundary in the reference dialog box to always default to NONE and by Visible Edges default to DYNAMIC.
You haven't told us which version your using, but since Connect Edition U14 that this variable as been included:
MS_REF_DEFAULTSETTINGS = drawingBoundary=none
And for Dynamic visible edges use the following variable:
MS_REF_VISEDGE_ATTACH_STATE = Dynamic
To place the variables go to Backstage (File) \ Settings \ Configuration \ Configuration Variables \
Hope this is what your looking for.
José
Answer Verified By: Brian MacCartney
