I have a problem while I'm referencing a DWG file, I can't prioritize it.the priority level stays constantly on "0".I've searched the forum, but didn't find any solution to this problem.It accrues only on CONNECT version. The DWG file that is on "-5" priority was changed in V8i version.
Am I doing something wrong? How can I change the priority of DWG references?
Thanks in advanced,
Yoav
Hi Yoav
A DWG is a 3d file, this means the priority option is disabled as it will not work if the DWG is rotated. Same as a 3d DGN
However, within the DWG open and DWG reference attach dialog boxes, you can select an OPTION icon to open/attach the DWG as 2d. This will then allow the priority option to work.
Hope this helps
Ian
Answer Verified By: Yoav Degani
Thanks Ian. Works great!
