I´m taking a course under the Ingeoexpert platform, I have downloaded and installed Microstation Connect.I have the AccuDraw bar in place but when I try to open the AccuDraw to change the operation and performance settings, nothing opens.
Jesús García Permuy said:open the AccuDraw to change the operation and performance settings
What do you mean by "change the operation and performance settings" ?
Does your status bar shows accudraw in focus ? Check the screenshot attached.
Following link might be useful:
docs.bentley.com/.../GUID-F381F9D9-1325-A10F-97B1-9A4D0563CE37.html
Answer Verified By: Jesús García Permuy
Incase you want to open Accudraw settings dialog box, you can do it from Drawing > Drawing Aids > AccuDraw. Alternatively, you can search 'AccuDraw Settings', check the screenshot.
I have the Accudraw bar on, but when I click to show the dropdown, the dropdown does not appear. I click and it does nothing.
Accudraw isn't a drop-down. it is a toolbar that is often docked along the margins somewhere. The settings also is a standalone dialog, not a drop-down. Clicking the Accudraw button would just turn the docked dialog on and off.
MaryB
