When i close MicroStation with the X in upper right corner, then it is stil running in the task manager and the designfile in which I was working is in Read-Only mode
i am working with MicoStation CONNECT Edition Update 14 - Version 10.14.02.01
how can i fix this?
greetings Johannes
Hi Johannes,
This is a bug with the recent versions of CONNECT Advisor affecting Update 13 and 14 and all PowerPlatform products. Make sure to close CONNECT Advisor before quitting or change it's options to prevent auto startup. Some of our users have even uninstalled it out of frustration.
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/203679/openroads-designer-doesnt-close-tasks-stay-open-in-task-manager-that-have-to-be-forced-closed/611083#611083
https://communities.bentley.com/communities/other_communities/sign-in_assistance_and_web_services/f/cloud-and-web-services-forum/202291/bentley-connect-advisor-not-exiting-with-microstation
There is also an issue with the main GUI closing much earlier than the software itself when using the top right X button since Update 13, but it's usually in the order of 5 seconds.
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
