Dear All,
I have a dgn file (version 7).
I want to automatically assign the value of Fill to Color for all objects.
For example, if the Fill value is 5, the Color value would also be 5 instead of 0.
I hope all of you can help me.
Thank you very much!Yours sincerely,ND Liem
You need Bentley Map for that. For Microstation you would need to develop a macro similar to SLYR for QGIS.
Here is a VBA example - Closed to Open Source GIS First Steps in Reverse Engineering ESRI’s Layer Definition File Format (http://www.diva-portal.se/smash/get/diva2:1086367/FULLTEXT01.pdf)
Thank you for your idea. Do you have Bentley Map?
Yes I have but not a commercial license.
Tried to import VBA code from the thesis appendix but it doesn't seem to be valid VBA structure.
ESRI-LYR-open.mvba
Could you help me convert dgn to shp using Bentley Map? Thank you very much!
