Hi, in CE Update 14 (fresh full install) I have unchecked "Use Online Help" in preferences. Neverteless, when Help is called from Microstation File menu, the Online Help is shown in a browser. Searching the file system for "MicroStation.chm" only finds this for V8i. What's going wrong here?
Hi Robert,
Robert Schwenn said:Searching the file system for "MicroStation.chm" only finds this for V8i. What's going wrong here?
Since the first release of Connect Edition back in September 2015 that the help as been release in HTML form, so you have to find it in your C:\ProgramData\Bentley\Documentation\Microstation\your version\en\htm\index.html
So your search only finds the v8i version writing in the old chm format.
Robert Schwenn said:Neverteless, when Help is called from Microstation File menu, the Online Help is shown in a browser.
Are you sure that it's the online help opened in your browser, or it's the offline help opening your index.html file (offline help) - see the adress if it points to your index.html file location?
José
Answer Verified By: Robert Schwenn
Ah, ok. It works as intended. I didn't see the difference because I expected the chm to be opened.
Thank You, José.
