Hovering over an element no longer shows the pop-up info that it usualy shows.
Now when hovering over an element, it selects the element and then it shows the pop up, this makes drawing , extreemly annoying and takes way longer than excpected, please help!!
The pop-up info in accusnap is turned on, so is the identify element option, and still the same problem accures.
The option to display the pop-up information and whether this is turned off can be found under the AccuSnap Settings
https://communities.bentley.com/products/microstation/w/microstation__wiki/10302/enable-disable-pop-up-info
I have not heard of an option where it automatically snaps to an element but this may be related to issues with the User Preference File (UPF). You might like to try resetting the UPF and cleaning out the temp files to see whether this may remedy this situation.
communities.bentley.com/.../how-to-reset-user-preferences-and-delete-microstation-s-temporary-files
It doenst matter if the Accuusnap setting is turned on or off, it still function the same way, hovering over an element , does show the info pop-up and selects the element. I have cleared the Temp and reset the UPF and the problem still the same
delete the upf and let mstn build a new one
also here are my settings and prefes
as you can see in second pix ( click on it to see bigger) I'm hovering and it highlights without clicking which comes form first settings
Lorys
I have done that now and the problem still happens, I contacted IT department and they reinstalled it and the same problem occurs.Is it possible that another command is clashing with the accusnap pop-up command ?
I can't find anything that automatically selects an element, just preview. Perhaps you have a hardware malfunction, or the click sensitivity is so low it's clicking on its own.
Maybe , I'll try that on monday, maybe thats why, thanks alot for the answers guys
Lorys said: I'm hovering and it highlights without clicking
This is normal behavior when you hover over an element in Microstation. It is not being selected, it is just being highlighted so you know which element the pop up information is referring to. To actually select the element you need to left click on the element.
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
