So I have couple of elements under Level-A, they are all in blue, now instead of clicking them one by one, I want to change them all to red. I went to level manager and changed the Level-A color to red, however the drawn elements still remain blue. The only way I can change them to red is by clicking on each of them one by one, and going on element information and changing color to red. Please advise!
Hi Pratik,
Pratik Saha said:I want to change them all to red. I went to level manager and changed the Level-A color to red
If the elements did not change color when changing the level's color this means the color attribute for the elements were not bylevel. Elements who attributes are set to bylevel will take on the attribute settings for the level and allow changing the color of element to occur when changing the color of the level.
See the following wiki on how to change your element attributes to "ByLevel"
https://communities.bentley.com/products/microstation/w/microstation__wiki/14837/how-can-i-change-all-elements-in-multiple-files-to-use-the-bylevel-color
Regie
You can use level over-rides to do this it's a toggle in the level manager which will over-ride any of the element attributes & by level attributes.
You can use the Element Selection tool to choose that level and select all of the elements on it. Then the Change Element Attributes tool can be used to set them all ByLevel
MaryB
Microstation 08.11.09.829Power GeoPak 08.11.09.878Power InRoads 08.11.07.615
Pratik, there are several ways in which to control the color of an element.
1. by an actual color for its attribute (which sounds like what you are doing).
2. color is control "by level" - this is an autocad feature that MicroStation can use as well.
3. Level overrides - this is similar to the by level feature, but it is a separate function.
If you are not using by level or level overrides and want to change the actual color attribute from blue to red. You can select those elements and then change the color attribute for them. Either a selection set can do this or turn off all levels except the one containing the elements and select them, then change their color.
If you want to use by level for the change, the elements themselves have to have the color attribute set to by level in order for them to follow the change made in the level manger for by level attributes.
If you want to use level overrides, then you need to change the level manger from by level to overrides and change the color attribute for that level and then finally setting the level override option in the view attributes or the view you are using.
HTH
Tim
turn off everything except the level that has your blue objects,
Then select everything left on , and change tool to change the color of the selection or properties while still selected and change the colour there or change it to by level there and make sure the level manger has the colour you wanted.. either way works fast..
Lorys
Currently Using V8iss10
