Help, using connect update 14 version - I am trying copy a table from excel and paste it into microstation using special paste, in the Paste special dialog menu there is no data type for me to click on. Is there somewhere in the Configuration Variables I need to change, or is there something in Excel that I need to do.
see attached, this is how my dialog box looks like.
Your help will be much appreciate.
Maggie Smith said:I am trying copy a table from Excel and paste it into microstation
There have been a few questions about your problem in recent years. For example, this one may answer your question.
As Jon Summers mentioned there have been a number of discussion relating to this issue but I thought I'd highlight that the following defect had previously been raised to investigate this issue. It appears to be fixed for the next update of MicroStation CONNECT Edition (Update 15).
Defect 1097166: Paste OLE Object dialog not appearing when pasting from Excel
Hi, yes thanks, I came right,
