Aadarsh Tale said:I want to hatch the reference/non Bentley Raceway and Cable Management
Is your question about Raceway or MicroStation?
Aadarsh Tale said:I have attached an example file
You've attached a screenshot. It's hard to answer a question about reference attachments with only screenshot as evidence: post a DGN file!
3D LAYOUT_CONTROLHOUSE.dgn
Raceway.dgn
I have attached both the files, the control house file is a reference and I want every element of that DGN to be hatched so that I can distinguish between the raceway components and the reference elements.
Aadarsh Tale said:I want to hatch the reference elements
What is it that you want to hatch? Hatching applies to 2D planar shapes.
Aadarsh Tale said:control house file is a reference
That's a 3D model full of shared cells and meshes. There may be some planar shapes in there, but they are not immediately obvious.
Aadarsh Tale said:I want to use the 2D extraction
You've lost me! Your post is entitled Hatching the referenced file elements but you want to perform 2D extraction.
You should re-think your post, because it's confusing. Also, you seem to be asking several questions, so it might be better to create a new post for each topic.
Hi Jon,
Thank you for the answers on my post, I just want to make a distinction between the raceways and the reference file in the active view and I have managed to do that.
My other question was as BRCM only extracts the elements from the dataset and not the reference, so is there any MicroStation Plug-in which could be used with BRCM in order to extract the complete drawing in 2D. Any clue?
Aadarsh Tale said:My other question
New question, new post!
If your question is about BRCM then you should post in the Forum I mentioned previously.
Answer Verified By: Aadarsh Tale
