I have a jpg nearmap export in US survey feet with a jgw file. When I attach the file the coordinates are slightly off from the jgw file. I've tried toggling all the settings to see if anything would work but no luck. This is specifically EPSG 2278. What would be causing the shift in the coordinates?
In my experience it is not uncommon for Nearmap Imagery to be 'slighly off'. I generally have to attach it interactively and modify to suit existing CAD linework.
How much off? millimeters or meters? You might try attaching it with a different orientation.
From memory Nearmap is not ortho corrected. So the greater the height of objects above ground the greater parallax error or mismatch between ground and heights so your never going to to get perfect alignment relative to real survey ... especially say a freeway ramp over a road or tall building tops will tilt over and actually fall outside their surveyed base or title. But you get what you pay for...
Before we had Nearmap you needed to get a flight run for you if there was no library recent stock films, and then you paid a little extra for it to be ortho corrected this was done with overlapping photoruns and clever optics and it helped to reduce the parallax error...I believe this is still available from some agencies and is now done with clever programming and overlapping photos... but might be expensive to pay on top of nearmap.. ask near map if they offer the extra service for a specific site... but how perfect do you need it.. at what scale are you going to print anyway... my stuff is usually never more than 500 mm out, even if I capture it from Google Earth pro ( for free) that's not bad .
So now if you have survey you can adjust the position of the photography in your drawing sheet view to make it better you'll never get it perfect for large areas and it also gets worse around the edges ( I think due to the curvature of the earth) .. Well thats my 2 cents worth..
Lorys
