I have a jpg nearmap export in US survey feet with a jgw file. When I attach the file the coordinates are slightly off from the jgw file. I've tried toggling all the settings to see if anything would work but no luck. This is specifically EPSG 2278. What would be causing the shift in the coordinates?
I have all those settings matched up too. Are there any other settings that would say limit the digits on the scale?
What are the Working Units>Advanced Settings?
TN said:the coordinates are slightly off
How far is "slightly off"?
can you open the jgw file with note pad and post the contents here as a lot of the settings are in this txt file...
Have you other similar rasters in us survey ft open the jgw file and compare it with the problem one if same datum and same units then most of the settings will be the same except for the origin xy
Lorys
In my experience it is not uncommon for Nearmap Imagery to be 'slighly off'. I generally have to attach it interactively and modify to suit existing CAD linework.
How much off? millimeters or meters? You might try attaching it with a different orientation.
