I used to be able to use AXIOM with V8i to paste my tables, etc. and it would look good.
Now with CONNECT, AXIOM is not available anymore and I will have to paste directly from the clipboard.
This works but it does not look as good or proportional. I'm pasting as a "link" via "corner" method.
Is there a way too make it look better or more professional?
thanks!
I paste by "Size" and that retains the proportion of the original spreadsheet. I can scale it up or down if I need like any other element, if the original size is too large or small.
You can also look into the use of MicroStation Tables, which are now part of CONNECT. They work more like a data link between your spreadsheet and a table of native MicroStation elements.
MaryB
Thanks. I tried your method but it still looks like this:
The fonts are so close together.
Hi Ricky,
I just tried pasting from Excel using the "link" via "corner" method. It looks nearly identical to the original in Excel.
It even maintains the quality no matter how I scale it.
I don't have any idea why you're getting different results.
Will this help https://communities.bentley.com/products/microstation/f/microstation-forum/200796/ceu14---why-doesn-t-paste-from-clipboard-work-the-same-in-ce-as-it-does-in-ss4
