MicroStation CONNECT aborts during translation self-referencing models from command line
The problem can be duplicated with a simple DGN file, created from MicroStation seed file, when the model is self-referencing and BCNV file contains string:referenceMergeOptions.mergeSelfAttachments=3Steps to Reproduce1. Create new DGN file with self-referencing model (see file test_0.dgn)2. Open "Batch Converter" tool in MicroStation Connect. Create new BCNV file for convertingtest_0.dgn to DWG. Make sure that it contains parameter "referenceMergeOptions.mergeSelfAttachments=3" (see test_0.bcnv)3.Close MSConnect4. Run from Command Prompt window:microstation.exe -wabatchconvert "-iC:\projects\test_0.bcnv"Observed (Incorrect) Behavior5. The conversion process seems to silently abort in the middle. The output file is not created. The log file contains information abort process's start.Expected Behavior6. Expected Batch Converter launched from the command line to generate the DWG file and not abort.
Note: If we skip steps (3) and (4) and launch the conversion from MicroStation's GUI, the Batch Converter successfully creates the output file.
Waiting on exact CONNECT version number from the user. Pretty sure it's update 14, so probably 10.14.04.04.
I logged this as SR 7001155809 today.
Here are the MicroStation CONNECT versions we've tried this in. We reproduced it in both versions:
Bentley has reproduced this and logged it as Defect Report 1113251.
Thank you for updating this thread with a defect number. The development team will review it and plan the fix accordingly.
Thank you!
I have checked on the U15 Latest build. It is reproducible. We will update you on this defect.
