I'm seeing the following message in the message center:
I don't see any change in the behaviour of the program.... any idea what this is?
I'm using MS 10.14.02.01
Pedro
Does this message appear on all files?
Ian
If the file format is non DGN then check this link
Why would MicroStation be throwing an AutoCAD error?
MaryB
Without the file and steps to reproduce, it’s difficult to comment. But error codes can be from System, Third Party etc.
MaryB said:Why would MicroStation be throwing an AutoCAD error?
I guess it's because the error potentially can come from RealDWG library, used to open DWG/DXF. And this library comes from AutoCAD ;-)
Jan
