Hi (Bentley),
Can you add a GEO coordinate ERTF89 UTM sone 32
And is there a way to do this manually inside MicroStation?
Thanks in advance
//Christiaan
Christiaan Post said: is there a way to do this manually inside MicroStation?
You must tell us the version (e.g. v10.x.y.z) of MicroStation you are using.
I have performed a quick search in MicroStation CONNECT Edition (Update 14) and could not locate this GCS in the library. This version currently does not have the ability to add new GCS but you could perform this within Bentley Map | OpenCities Map.
communities.bentley.com/.../--defining-a-custom-coordinate-system-v8i
What if they don't have MAP, and can't justify the expense of an entire software application for just one GCS?
MaryB
Then they're screwed. The Bentley solution to everything is whip out another 10 grand. Greedy predatory thieves. They weren't always like this.
MaryB said:What if they don't have MAP, and can't justify the expense of an entire software application for just one GCS?
They could contract with a company that does have Map to produce that GCS.
Bob Rayner said:The Bentley solution
Then they could sell the new GCS to Bentley Systems.
