Hi (Bentley),
Can you add a GEO coordinate ERTF89 UTM sone 32
And is there a way to do this manually inside MicroStation?
Thanks in advance
//Christiaan
Thanks Guys,
The first part is working, but what do I need to fill in here for me it's quite confusing if I compare the (WKT)
Hi Christiaan,
I am not a Bentley Map user but I looked in the Bentley Map Help and found the following information.
Bentley Map provides a keyin to import a text file with WKT, create and assign a geographic coordinate system (GCS). This text file is typically an ESRI .PRJ file associated with a SHP file.
Key-in: MapCSUtilities ReadWKT filespec
By using this key-in and the WKT file I downloaded from https://epsg.io/5972 I was able to create and assign the GCS shown in this image.
Hopefully this helps.
Regards,Ron
Hi Ron,
Thanks but I don't use Bentley Map either just MicroStation CE Updt 14, so how could I fix that?
We added the ability to create GCS in U14
To Create and Define a User Coordinate System Library (bentley.com)
Samir
Christiaan Post said: what do I need to fill in here for me it's quite confusing
When you edit the GCS just copy the entries shown in my screen shot.
Answer Verified By: Christiaan Post
