Hi (Bentley),
Can you add a GEO coordinate ERTF89 UTM sone 32
And is there a way to do this manually inside MicroStation?
Thanks in advance
//Christiaan
Andrew Bell said:I have performed a quick search in MicroStation CONNECT Edition (Update 14) and could not locate this GCS in the library. This version currently does not have the ability to add new GCS
Are you sure? That's not what the Help says.
https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v16/en/GUID-AAF77C12-776B-41E7-A685-1C12EC8D3154.html
Once you set up your custom User Coordinate System Library find one delivered by Bentley that is close to the one you want. Copy it from the Library into your user library. Once in your user library you should be able to edit it and change to what you need.
Rod WingSenior Systems Analyst
Thats fine but there is northing I can find in the help where or how you get the actual numbers to edit the datum...
I remember in V8i I save an article that you can manually re-register known points and maybe create something of a correction but its still not a new datum...
Maybe buy global mapper (GIS pakage) license is <$900 AUD import with your current recognised datum and transform to missing datum then export to DGN (rename your model ERTF89 UTM zone 32 .. then only work in world coincident...
But I agree that its not good enough bentley should give use a FREE tool or utility to make datums in Microstation or take requests and put new ones in a repository for users to download...
Mean while try the GIS forum and some kind soul may make it for you in their Bentley Map can only ask right?
But I still don't see why Bentley cant take requests and make it for you to add from a repository then they only need make it once per missing datum... not asking for local datums made by a surveyor for a one off survey but World recognised datums like EPSG
Quick google search tells me its a europe datum and the equivalent is EPSG 25832 ( with E, N) or 5652 ( with variant N,E) for Northern Europe...
Look here https://spatialreference.org/
found your datum and here is the content of the prj file
PROJCS["ETRS89 / UTM zone 32N",GEOGCS["ETRS89",DATUM["D_ETRS_1989",SPHEROID["GRS_1980",6378137,298.257222101]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",9],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["Meter",1]]
but how and what you copy to make a new bentley datum is above my pay grade...
Lorys
Lorys said:Quick google search tells me its a europe datum and the equivalent is EPSG 25832
But that is the answer and this GCS is available in Microstation IMHO.
As a German I think the original Post does mean ETRF89 UTM Zone 32, practically the same as ETRS89 UTM Zone 32. Available in V8i and I think in MS CE, too.
https://epsg.io/25832
It is the standard reference system for the European Union and it is used with the UTM projection by almost every federal German Land Surveying Agencies.
REPLY on Ron Jones 16 Nov 2020
The connected vertical datum NN2000 to ETRS89(horizontal) , the Norwegian "Norway Normal Null 2000" height system wasn't on "my screen", so Ron's answer seems to be right.
Frank
Hi Christiaan,
Based on the image you posted it looks like you are refering to EPSG:5972 (ETRS89 / UTM zone 32 + NN2000 height) which is not a GCS delivered with MicroStation. You should be able to manually add it to you own custom library by following the Rod Wing's advice in his post. You can use the Well Known Text (WKT) data available at https://epsg.io/5972 to create a new entry for this GCS.
Regards,Ron
Hi
Thank seems correct Ron!
