Hi (Bentley),
Can you add a GEO coordinate ERTF89 UTM sone 32
And is there a way to do this manually inside MicroStation?
Thanks in advance
//Christiaan
Thanks Ron, Finally I get it working!
A great decision, 10 years too late
Frank
This is great however, I still cannot see how to import the DAT file (i think its a DAT file)
I compared the WKT file contents to your screen and I can't see where ALL the ellipsoid information comes from in wkt file ...
I understand that with Bentley Map and keyin, but I think the prj file ( for those without map) has all the information you just have to know which bits go where... your screen shot matches the prj file entries better but I still cant see where, even with the wkt file from the link , you get the ellipsoid data ie polar radius and eccentricity...? items 1 & 2 they are not in the prj or the wkt
And the source entry below that where does it come from as it dont look right..
Lorys
Lorys,
As I said, I am not a Bentley Map user and don't claim to be an expert, but with that said, I believe those are derived values based on data in the GRS1980 (Geodetic Reference System 1980).
They were automatically provided by the Key-in: MapCSUtilities ReadWKT filespec
Regards,Ron
