My Microstation for "home use" has stopped working. I have been using the "home use " product for the past 10 years for home use projects. Can the group recommend a 2D CAD program that operates similar to Microstation that is reasonably priced for occasional home use?Thanks, Brad Kuhn
Many Autocad clones out there some even free
Sketchup the free version is pretty good...
I did a google search for you list a few
Qcad isnt bad, some of these clones can only do 2d but if its free you cant complain...
https://solidface.com/free-autocad-alternatives
Lorys
Answer Verified By: Brad Kuhn
Thanks Lorys, I will check them out. I just need basic 2D CAD, but the program must read DGNs.
Brad
Very little out there will read dgns for free....some of the low cost ones for business <$1000 will read dgns ...
It would appear DualCad 2.93 would suit your needs best as it handles DGN including ref attachments and is free and under 2MB download.. use google to find it only available from an info site doesnt seem to have a developer website but screen shots look great... hey its free give it a try
Thanks again, Lorys I did see DualCad in my search as well. I will look more into it. I don't mind spending a little on the right porgram. I would like it to be somewhat similar to Microstation and at least operate on DGN files.
Just to note that "Home Use" licenses are provided as a benefit for any company on a SELECT contract and should really only be used for training purposes at home. The "Home Use" benefit is currently not available with CONNECT versions of Bentley software.
communities.bentley.com/.../home-use-program-update
If you are looking for 2D CAD software you might like to consider MicroStation PowerDraft which is a cut-down version of the main program. It is of a lesser cost than the full MicroStation software and should cover all of the operations you would be used to doing with 2D drawing.
store.bentley.com/.../11503--MicroStation-PowerDraft
