Hi
I'm using configuration variable link harvesting files starting with e_ (e_*.dgn). This works in V8i but not in CE?
In CE works only if I use *.dgn, but i'ts not enough.
Jussi Sunnari
Kemi, Finland
Sorry for the major delay in response to your issue but would you be able to provide further details as to how you would be using this configuration variable link to harvest files in Explorer? You might like to provide some screen captures to assist with your explanation.
This is how I used the configuration variable link to retrieve models from directories on the Microstation V8i
The same way does not seem to work in CE?
Apologies but there might be language issues here. I'm not sure exactly what each part is that you're defining in Explorer. Maybe if you could outline a step-by-step workflow for how this is being performed and what you are expecting to achieve.
The image in the previous message is from project explorer. The configuration variable link contains an environment variable, for example: _OSTO_TALUE_2DLAI, which looks for dgn files whose names begin with the letters e_. This works well on the V8i, but not the CE.
Which Product and Version are you running?
In MicroStation CONNECT Update 15 I was able to populate the Explorer dialog using the same custom variable (set at Workset Level) by picking it from the list of available variables, although looking at the Link Properties dialog your displaying the Configuration Variable '_OSTO-TALUE_2DLAI' comparing this with mine its showing as '$(_OSTO-TALUE_2DLAI)'
If you edit your Link Properties to '$(_OSTO-TALUE_2DLAI)' does this the resolve your files as expected ?
Did you manually enter the variable name or pick from the list or use a different workflow, perhaps migrating existing data from V8i ?
Carl Myhill
Technical Support Engineer
Bentley Systems
