How do a copy and paste a selection of cells to a new location in a Table? See below. I want to copy tyhe highlighted cells to rows 9 - 14. How do i do this?
Hi Stuart,
Ideally, shortcuts Ctrl+C & Ctrl+V should be used for this. Alternatively, copy and paste option from clipbopard. Both these options are not working at the moment due to a defect #1035827.
Please raise a new service ticket and ask for it to be linked to this defect.
Karan Sharma said:Ideally, shortcuts Ctrl+C & Ctrl+V should be used for this. Alternatively, copy and paste option from clipbopard. Both these options are not working at the moment due to a defect #1035827. Please raise a new service ticket and ask for it to be linked to this defect.
I tried Ctrl+C & Ctrl+V but as you have noted this didn't work. I will raise a ST but in the mean time I guess that the only way of doing this is to manually fill in the cells.
Well, I'd have expected such really basic use of tables would've been tested prior to release...
f.mandoki said:Well, I'd have expected such really basic use of tables would've been tested prior to release...
I agree.
Microstation functions like a joke... When tables copy-paste functionality will be fixed?
