We have the ability in U15 to total in tables. How do I total the highlighted cells in the table below?
stuartw said:How do I total the highlighted cells in the table below?
That question is touched on in this post.
Jon Summers said:That question is touched on in this post.
Thanks, but that i all about Reports. I don't have a report, I have a table which I want to total the column.
How do I do this?
stuartw said: I have a table which I want to total the column
A MicroStation Table is not an Excel worksheet. It doesn't have arithmetic or algebraic functions. It's a DGN element whose purpose is to render tabular information from a data source. That source can be external (Excel, CSV) or internal (a Report).
stuartw said:I don't have a report
Your screenshot shows that you have areas in your Table. If you're not using a Report to harvest those area data, then how do you do it?
stuartw said:We have the ability in U15 to total in tables
Where have you seen that statement? A MicroStation Table is not a spreadsheet. It doesn't have arithmetic or algebraic functions.
I guess that I have misread this as assumed that a table, which is not dissimilar to a report, would have the total function. At the moment tables are practically useless, which is why I copy and paste a spreadsheet into my drawings.
