when I set active level using Attributes toolbar, the level is set, but also dialog to choose "Recall level filter" appears. is this WAD? and I'm not able to change level of existing element using same tool - again, this "Recall level filter" appears and when I click OK, dialog closes but selected element's level is not changed ...
this "Recall level filter" dialog does not appear all the time, haven't found reason yet. anyway, it's quite annoying.
-- edit --
just to be clear, I'm using Attributes toolbar docked at the bottom edge of the screen, not Attributes group in Ribbon. using Ribbon everything works as expected
thanks
I have tested the operation of setting the Active Level from the Attributes toolbar, rather than the ribbon tool, and have not seen any extra dialog as you've described. Would you be able to provide a screen capture showing this dialog? Also, is this occurring when selecting all levels or could this be related to specific types of levels, ie. levels from a Design Library?
I am having the same issue ever since the 15 update. When I try to change my level in the attributes toolbar (not the ribbon attributes under "home") it pops up a "Recall Level Filter" window. It seems no matter what you click in that window, Ok, Cancel, or choose a level filter...it will not change to the level selected in said attributes toolbar. I always have my level filters set to none and use DOT levels. I did notice that it will change to some levels, but not the "xxx_ep" levels that I need to use for FDOT. This is when the recall level filter dialog pops up. I can take some screen shots if itll help, I believe Peter and I are having the same problem.
Here are some of my screen shots. I believe Peter and I are having the same issue. The first one is the current active Level, second one is me trying to change the level, and the third one is the dialog that pops up. Thanks for any help.
I have raised the following Defect to address this issue.
Defect 1114651: Setting Active Level From Attributes Toolbar Displays "Recall level filter" Dialog But Not Changing
thank you both. yep, it's the same issue I have.
btw, one minor additional thing, when you invoke Attributes toolbar (using CTRL+T and selecting Attributes), the level part of the toolbar is empty. it does not show active, not any other level.
/pt
