Have just found that Trim to Intersection is either broken in U15 or at least doesn't work as v81. See screenshot below and sample attached.
I started Trim to Intersection using PM 7,4, picked the angled part of Line 1 and then Line 2. What I want to see is the result as shown in V8i-Complete, but didn't in U15.
I'm assuming that this is a bug in U15.
trim to intersection file.dgn
Could it depend on which end of the lines you click on?
f.mandoki said:Could it depend on which end of the lines you click on?
No. I clicked on the same parts of the lines in U15 and v8i and got different results.
Bentley - This appears to be a new U15 bug.
stuartw said:Bentley - This appears to be a new U15 bug.
Has anyone at Bentley had a look at this?
It appears David Trejo-Rodriguez is investigating your issue from the Service Request that you raised with Bentley.
Looks like this is a Defect 1100007. Trim to Intersection tool is not working properly with line strings.Same happens in U14...
