Have tried this. It's just horrible, adds nothing to the UI and doesn't work with my custom icons.
I also find it curious that this was a priority, given how many bugs, regressions and improvements have languished for years.
MaryB
Microstation 08.11.09.919Power GeoPak 08.11.09.918Power InRoads 08.11.09.918
The opportunity to lure Autodesk users to Bentley platform was wasted some years ago when Autodesk moved to SaS so fancy black theme will not help much or had to be there 5 years ago.
Hello Stuartw,
It appears from the image you have attached that, the Microstation didn't restart after applying Dark Theme. This setting requires a restart to get the full effect of "Dark Theme" though we are trying to reduce this barrier. Please refer following document for details.
docs.bentley.com/.../GUID-184C76D7-B96A-4814-A823-6A1E2D70E236.html
Please let us know if the issue still persists after restart.
Thanks and regards,
Dhiraj Badgujar.
Dhiraj Badgujar said:Please let us know if the issue still persists after restart.
It still persists and has messed up the location of my docked tools in the process.
Bentley wastes the bulk of an update to make MS look like AutoCAD in CE..... CE still can't accurately and reliably translate from dgn to dwg requiring users to use v8i... irony.
