I have opted for a cell while placing points along the element. I'm expecting the orientation of the cell should appear perpendicular to that respective location. Is that possible?
Sanjeev Kajarekar said:I'm expecting the orientation of the cell should appear perpendicular
Is this what you're looking for?
Have you tried the 'Construct Array - Along Path' tool with Rotate Items = ON & Distance = 100 ?
To Create an Array Along a Path
Answer Verified By: Sanjeev Kajarekar
Really appreciate for the perfect solution. That's what i am looking for. Thank you so much.
