I work a lot with mapping to authorities, and they have many requirements regarding line styles.
One requirement is to have line styles that are not "broken" at breakpoints, you want the line style complete throughout the mapped line.
When using "Run through corners" in MS (v8i and CONNECT) the setting is not retained when exporting to dwg, how come? Does anyone know any solution to this? How can I get the line style to maintain "run through corners" in to my exported file.Kind Regards,Elin
What do you mean with "Remap table"?
It is under Save Options - Remap
But to edit the CSV you need Microsoft Excel with macros enabled. Also it may say that this is meant for upgrading files to newer format but in real life this is used everyday because of MS unresolved issues with DWG conversion.
Okay, I understand.
But that is not my main problem in this matter.
I generally just wonder why the "Run through corners" setting is not maintained when selecting it. That the setting disappears when you open the file again or choose to export it in another format.
Forget about export it is impossible to retain it as DWG format doesn't support this. Only what is left is to understand why DGN doesn't save this setting it may be because the lines are imported in file and not actually coming from RSC. At least we no longer use RSC but import our lines to DGNLIB which is linked to workspace so when new empty file is opened and lines are placed the linestyles get automatically imported in file so no RSC is needed on file delivery and enduser see the DGN same as we do. This approach is not possible using DWG format as it still requires to deliver SHX file to view linetypes which uses symbols.
We do work with DGNLIB, DGNLIB that have line styles picked/connected to lin- and src-files. And we do get shx-files when we export to dwg, shx-files that we send to our custumers. So it is no problem with the line styles. The problem is just the "run through corners" as I discribe.
